4 members (Joe H, baldeagle, panic, 1 invisible),
74
Mod | | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | Will OEM rally rims from a 73-87 generation chevy pickup fit on a 60-66 body Style? I have a set of 15x8 but the hub has centering tabs which prevent it from fitting on my 2wd 65 short step. However I note some 73-87 rally rims do not have the tabs??
Thanks | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Usually the 6 lug rally wheels off of a 4X4 work well. They also accept disc brakes too. I have a 65 short step. I prefer the old school slots myself. Not easy to find OEM rallys or slots with 6 lugs. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The true rally rims are 10 slot and do not have "centering tabs". Whatever that is........ Lots of them on Ebay. Sometimes called "Blazer Wheels", Argent silver with plastic caps.
The "hub"? Is that the hub on your truck? If you are talking about the hole in the rim having "tabs", it sounds like you have hub centric rims? You want lug centric...as in using normal tapered lug nuts.
73-87 Chevy 10 slot Rally wheels fit on 60-66 Chevy trucks. There are rally wheels and then there are, so called, rally wheels. Bogus...and there are 88 and up.........they don't fit.
Rally Ralley Ralleye Really?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | Having power brake and steering upgrades done so truck is at the shop Will follow up on wheel selection in a later post | | |
