6 members (Jon G, baldeagle, RLB, frogfarmer, ndkid275, Hush), 74 guests, and 2 robots.
Topics128,087
Posts1,055,974
Members48,430
#1231576 08/23/2017 6:05 AM
Hello
My 65 short step needs a new antenna
The base appears to be ok so I just need the antenna ( I believe the original base has the ball assembly, correct? Not near the truck so I can't take a look)
LMC shows the complete assembly for about $60. Assuming my base is ok any idea where I can get just the replacement antenna portion without having to spend money on the entire assembly?
Just GOOGLE radio antennas and thousands will appear. I did the exact search about two weeks ago and found hundreds of replacement masts. Just search your particular style and click, it will soon be at your door. eeeek
