3 members (Leo, Gdads51, 1 invisible), 171 guests, and 3 robots.
Topics128,088
Posts1,055,995
Members48,430
#1231471 08/22/2017 7:21 PM
So I went through the process of replacing king pins, tie rod end and drag link ends this weekend.
Wanted to ask a simple question, if while greasing the king pin zerks, particularly the lower one, does grease somehow get to
the thrust bearing? Seems like alot to ask to have to repack that bearing all the time.
54 1/2 ton PU
Yes it does and you should see it ooze out of the bearing.
1951 1 Ton Completed
As truckernix posted: 18. King Pin thrust bearing?
See the appropriate grease/lubrication fitting.
