3 members (JoergK., 49nut, dbwr), 176 guests, and 1 robot.
Topics128,190
Posts1,057,342
Members48,469
#1231328 08/21/2017 10:15 PM
In a 1958 1/2 ton how do you remove the upper steering bearing? Can it be done without removing the column from the truck?
need to take off the wheel is all - the bearing has a flange that sits on top the mast jacket - use something like a small stiff putty knife or screwdriver to gently tap up on that flange until you can get hold of it - just a press fit, not too big a deal
Make sure you unhook the horn. wire. It's easy to break.
