7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | The Rochester B on my 1950 216 had no model number tag. Suspect it is a '52 or later by the two fuel holes on the venturi bar. Somewhere I read that the last few digits of the model number are stamped somewhere on one of the castings. Looked all over but must have missed them. Any Help?
| | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Got the info. Too bad my tinfoil tag under a carb screw went away years ago. Might just be possible that there are some numbers stamped into a gasket mating surface somewhere inside.
