6 members (Otto Skorzeny, Joe H, Gdads51, Rusted Nut, fonz8261, 1 invisible), 205 guests, and 9 robots.
Topics128,074
Posts1,055,999
Members48,433
#1231081 08/20/2017 3:11 PM
I have replaced the universal on my 53 3100 and am wondering what you guys use on the ball collar shims as sealant.
I have used:
- nothing, which is unwieldy during testing/fitting/adjustment procedure
- blue gasket sealant, which is messy and awkward
- white grease, which made for easy adjustment, and maybe a little swelling of the paper shims?
I concur with tcdermam and to add,
Make sure all mating surfaces are thoroughly cleaned and the bolts are torqued to specifications.
Universal Joint Ball (Housing) Adjustment
Page 1
Page 2
The four Universal Joint Ball (Housing) collar bolts, 8-12 ft. lbs. Torque.
The four Universal Joint bolts or cap screws, 25-30 ft.lbs. Torque read under assembly
The one Universal Joint front yoke attaching bolt, 15-20 ft. lbs. Torque
Don't forget the two U-Joint bolts/cap screws lock plates.
Note: The Universal Joint Ball (Housing) collar on the 1/2 ton trucks & Passenger cars equipped with Hydra-Matic / Powerglide transmissions use six bolts.
There is no change in torque spec
Thanks for the info.
Because the shims/gaskets are a little soft, the 4 retaining bolts tend to bend the ears of what Chevrolet called the Collar.
I always clamp the four ears, one at a time in my vise and give the collar a bump to straighten them.
Do not worry if you over bend the ears, as they will be pulled back in place with the bolts.
My Blog
