2 members (JW51, 78buckshot), 86 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#1230867 08/19/2017 1:40 PM
I believe my brake drums are out of round because I cannot get consistent adjustment. I will work to get them adjusted then rotate the wheel and it is very loose. Anyway, I spent yesterday morning going to about 4 places around here that service trucks. none could turn the drums I have. they said we could potentially order more but would have to remove it to get model or casting information. For what its worth, the truck is running and stopping ok I am just wondering what others here have done with their drums.
GJ
1959 Chevy 8500 - Spartan 80
366 BBC
New ones are likely going to be difficult to find. Turning drums is an option, but then you really should have oversize linings. I still have a lathe big enough to turn 16 1/2" drums but I don't use it any more. The modern non asbestos linings cause hot spots on the drums that won't cut. If it is stopping ok, I would leave it alone.
I assume you're working with something bigger than a pickup, right? You might be experiencing a situation where the shoe isn't concentric with the drum once the adjuster is loosened. On medium-duty truck brakes with the Lockheed cam-type adjusters it was not uncommon to get a little drag after tightening the adjuster to achieve drum lockup and backing off to let it turn. The problem was that the shoe didn't retract evenly and gave the impression of the drum being out of round. If the pedal height is good and the drums don't heat up after driving for a while, you're probably good to go. I assume you're not hauling max loads routinely, right? If so, you'll need to back off the adjusters a little more than usual to allow for expansion of the brake shoes when they get hot from heavy braking.
i drove it around 30 miles yesterday. I should have felt the drums to see it they were hot. I do have good pedal and it stops fine. I need to replace the shoe linings on the driver side as they were soaked in differential oil when I got it due to a bad seal. other than that I think its ok. Crenwelge, can you tell me more about oversized linings.
oh and yes this this is larger than a pickup. It is an 8000 series truck carrying zero load right now.
366 BBC
