3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Do any of you body guys have advice on tools & techniques for straightening out grill dents? I have a chrome '54 grill that's actually in pretty good shape so I don't want to mess up the finish. These dents can be tapped out rather than pounded.
Should I use wood as a dolly? Are there any household dools (sockets?) that can be used to contour the tight bends? Any advice would be great. | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Don't beat on the chrome surface. Use a metal or hard object with the original radius on the back side of the grille and tap with a hammer, (use a leather bag filled with sand to lay the chrome surface on,) untill you bring the surface back to the original contour. If there are sharp creases or streached metal you may not be able to restore without damage to chrome.
34 & 35 trucks are the greatest
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I found out that the chrome doesn't always stay attached to the metal when you straighten it out! I have seen where they use hand fashioned wooden drifts to accomplish the job. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks for the input. After doing a bit of tapping, I realized I have the capacity to do more harm than good. Some day I'll have it straightened, but for now its got "character and charm". | | |
