| | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | I am trying to find the part numbers for the front brake shoes on my 58 Viking 6500. Napa only lists a 14 inch shoe for the 6500. My truck is equipped with the Eaton 7000 pound front axle with 15x 2 1/4 inch shoes. Any and all info is greatly appreciated.
Rich
68 C30 CST dually flatbed dump 58 Viking 6500
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Found in my 1955-63 Chevrolet Truck Parts Book; 1957-59 Ser. 5-6 w/ 7000 lb axle...(Wagner FD-243449)....p/n 3745800 Hope this helps! Mike B  | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | If you have shoes that aren't bent or damaged, they can be relined. Try to find a shop that works on big rigs- - - -they will know if there's a business in your area that relines clutches, brakes, etc. Even shoes with the brake linings bonded to them respond to a little attention with a rosebud torch- - - -warm up the shoes and the linings pop right off. Then new linings can be bonded or riveted back on.
There are several auctions for 15" brake lining material (without shoes) on Ebay right now- - - - -cheap! Search for "2 1/4 inch brake linings". It's not terribly difficult to reline your own shoes- - - -you just need the right size rivets and some new lining material. Jerry
| | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | Really, I never considered relining myself. I wonder if their is a youtube video that outlines the procedure. Any idea how you determine the rivet size?
Rich
| | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | Thanks for taking the time to look in your books for me Mike.
Rich
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I even have a floor mount riveting tool, never have used it, though.
Ed
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The hole size in the brake shoe determines which rivet you need. The rivet heads and the pre-drilled holes in brake linings are standardized, and there are thousands of brake rivets at dirt cheap prices on Ebay, leftovers from closed down parts stores, etc. If you don't have a riveting machine, just clamp a flat tipped round punch in a vise with a little bit of the punch sticking up, and use that as an anvil while you buck the rivet with a piece of steel round stock and a big ball peen hammer.
If you get the lining material in a bulk roll and it's not pre-drilled, a step drill can be made by carefully grinding a regular drill bit to match the hole in the shoe and create a counterbore in the lining for the rivet head. Use the quill stop on a drill press to create a uniform-depth counterbore for each rivet. It's a lot easier with a dedicated relining machine, but a work-around isn't impossible. Jerry
| | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | Thanks for the info Jerry. It seems the brake part numbers Mike procured for me are no longer available. Google has turned up nothing. With neither the front or rear shoes available for my truck, investing in relining might be a reasonable investment.
Rich
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I am sure you have an old school clutch and brake shop somewhere in Pittsburg. Ask around, they are often obscure little shops in remnant automotive/industrial areas. I had the brakes relined using my shoe cores for a relatively decent price. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There is a place in Denver, CO called Clutch Exchange if you can't find a place near you.
Ed
