4 members (54farmtruck, Rich'sToys, Southerntruck, klhansen), 332 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
Page 2 of 6 1 2 3 4 5 6
Fox
Offline
I've never heard of those before!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Left side running board... Done!!! I just have to drill holes to mount the apron and I can call this little adventure of creating dually fender extensions done!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Dually done!!!!! I will post pictures when I get a chance Bolters as I do think I am done the dually extensions. I did not get pics yet as I took them apart to fix the stock running boards and fenders. I then proceeded to slice my hand wide open down to the bone and narrowly missing the tendon of my index finger. Bad one. You could see the bone, the tendon sliding back and forth. It was a dirty one!
Maybe I'll sand the cab epoxy in prep for body work.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
I'm nearly done refabricating/repairing the stock running boards for the single rear fender. When I finish, I will reassemble the completed dually and post pictures. Thanks for the messages and questions guys.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
So I've become tired of fixing rust, and dealing with rust, and blowing holes in rust, and I have decided to build new running boards and splash aprons for the one ton. I have cut a 48" long piece of 10' exhaust tubing into 1/4's. This pipe has the same radius (+/- 1/16") so I will use this to build my own splash apron. It will be much heavier and may require extra bracing, but it sure beats trying to fix the bent, old, rusty ones I have. I am still waiting on getting my new boards cut and bent. I will post when I get a chance.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
I've got my steel bent and I have begun welding together the pieces for the single fender running board. I also built new splash aprons out of 10" exhaust tubing. They turned out pretty good. Still working on these... Almost there. Yeesh.
http://s1372.photobucket.com/user/f...age_zpsczg8udjz.jpeg.html?sort=3&o=2
Camp Commandant
Camp Commandant
I love it! Really cool work. I still think it someone could produce the long beds, dually fenders and running boards, there would be a whole lot more ton and a half and two tons on the road!
Outstanding project.
~ Billy
1959 GMC 860 | Pictures
Fox
Offline
Right hand side single runnin board complete. I have the left side to finish welding out and planishing. They've turned out pretty good. One more week and I will have this dually/single wide box finished!!!!! Pictures coming! Tune in next week kids. 😀
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Done! The single and dually boards swap out quite nicely. The new splash aprons are solid. My wife and I went for a drive to celebrate and met a new neighbor as he came over after I pulled into the driveway. He was happy to see that I "got her going."
I'm going to change gears and strip the front fenders, strip the rears and repair then DA the hood. I actually had to think, "Now what do I do?"
Thanks for all the views and comments fellas.
http://s1372.photobucket.com/user/foxj12/library/?view=recent&page=1
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
As stated before I love the rear end shot with that dually stance.....great job
Dan
Hey Fox, Great job on the extensive metal work.
I was down in Sylvan Lake Wednesday for a safety course, next time I'm down or in the area i'll send you a message and try to stop by.
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Fox
Offline
Sounds good! I've never met a fellow stovebolter!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
I began to mock up how I would mount my license plate tonight. Because I built my own rear bumper bracket, which in turn moved the bumper up and in towards the bed, the bumper sits higher than stock which interferes with the stock license mount. I will create a drop bracket that will mount the plate below the bumper. I don't like how the stock bumper sits low and you can see the frame and "underparts."
This drop bracket will utilize the light for the plate so it will still be legal. I considered mounting the plate under the gate in the middle of the cross sill, but somehow it seems to "clutter" the clean look.
What do you guys think?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
You have two choices, mount the plate almost straight using
mismatched bolts (find some stovebolts) to the tailgate.
Or just hang the plate with some bailing wire.
What was the light for, If your stopped The horsemen might not look for perfection.
But to be serious you have done exceptional work.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Fox
Offline
I still have to upload some new pictures. I have built the bracket for the license plate and have used some JIC bulkhead hydraulic fittings and 1/2" stainless steel tubing to encase my light wires. It will look pretty clean when done I hope.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Here are some new photos. They show the tail light wires hidden, the license plate and a "before and after" of the rear fender as I continue to beat on sheet metal.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
I assembled my little blast booth to catch my excess glass and have started to strip down big pieces and parts of my 1 ton in prep for primer/bed liner (depending on the part). I have discovered that the "mill scale" on the new steel is difficult to get off with the blaster. However, the surface rust stuff comes off like dust. So, I have put out those new pieces I have built overnight, wet them down and will blast them when they get a nice flash rust on them. It really is easier to blast off. I figure that it won't matter rusting because I'm taking them to squeaky clean before I prime/liner it.
http://s1372.photobucket.com/user/f...age_zpsddgsh6rp.jpeg.html?sort=3&o=0
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
It has been a while but here is the 9ft box ready for primer! Woohoo!
https://goo.gl/photos/bAsFh3oTTy441G5Q8
https://goo.gl/photos/JGPfx1KFLY92Kpsx5
https://goo.gl/photos/2L44XDxQhkZ99Hqj8
Hopefully I will have it primer by the weekend.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox, great job, glad you're back, looks like you've been busy! Thanks for bringing us up to speed on your project. Love the pictures, I'll be anxious to see how it all turns out. Regards, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Fox
Offline
She is primed. I will have the front and rear fenders blasted and primed within the week!
https://goo.gl/photos/vZXKYhF2stWw87xX8
https://goo.gl/photos/k7bhU5cEkh3a5jVk8
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox,
As usual, NICE!!!!
You can really see your skilled metal fabrication even with primer!!
Can't wait for color.
Jim
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Fox
Offline
I as well! I think the semi gloss black on a big old one ton will look nice especially with the dual tires. But man am I beginning to hate block sanding. It was fun at first but not now. I have the time to do it and it is very satisfying knowing that I've done everything on the truck so far. It's easy to see how vehicles on tv can quickly become 6 figures. Labour isn't cheap and oh boy do I have a ton of labour into this ole girl...
Plus, 2 trucks more to finish after this one, then I'm retiring from the hobby. Maybe 😎
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Not really for the bed but here are the front fenders awaiting primer.
https://goo.gl/photos/bwwccKH195JkDGBN9
https://goo.gl/photos/kQo74uBFc9BZ7PWu6
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Rear fenders ready to prime. I still have to blast the fender extensions. Needless to say but I've got sand in my underpants!
https://goo.gl/photos/PEk5VKXodduuzK75A
https://goo.gl/photos/BKKGUvCNdc8qwrDB9
https://goo.gl/photos/wdHePhZwAAKiUt2g9
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Primed! A little tiny bit of filler for some of the bumps that exceeded my ability and they should be good to go for paint.
https://goo.gl/photos/297CDEmTvRWr1AgPA
https://goo.gl/photos/DUfdLWoj2sCuJxPHA
https://goo.gl/photos/Txy7PA5JYEqTvv1g7
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Hood, fender extensions, grille pieces (non chrome), core support, hood latch pieces, front splash apron pieces ready for primer.
https://goo.gl/photos/tHjqqqMVcTjL53uq6
https://goo.gl/photos/647vz8qGQ5vJyXFK8
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Today I mounted the front fenders and grill surround and began to block and work out the ripples and imperfections I missed in metal work. It looks pretty good and I really enjoy working out in the sunshine. It allows you to see so much.
I had 3 complete strangers (working in the new development) stop in and visit about the truck this afternoon!
https://goo.gl/photos/9qWFQaiarXspKhsK7
https://goo.gl/photos/tQKZYppv5ZAgRrFy5
It went really well today. Sunshine, 10'C, a brew with a friend, and sand sand sand!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Today I remounted the 5 window cab and sheet metal (originally from the Chevrolet 1 ton) onto the 1/2 ton frame (originally the GMC 3 window).
I have "completed" the body swap as I always wanted the 5 window Chevrolet 1/2 ton. The GMC 1 ton is a bonus and learning experience before I try to restore the 1/2 ton and my grandpa's 70 C10.
Here are the trucks as of tonight.
https://goo.gl/photos/BocgaT7GZ47h4rVcA
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
Gmc splash apron complete. Now to sweep up the shop.
https://goo.gl/photos/Xn1cRQfpTasUjJLa6
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Camp Commandant
Camp Commandant
Keep the pictures coming! Great progress.
~ Billy
I don't own a "new" AD model truck but have been living vicariously through your build. Nice work, it is really looking good!
Lots more pictures
Fox
Offline
Thanks fellas.
Here is the weekend's progress. I blasted and primed the apron and began to prep/body work the box and fenders. Sand, sand, sand, sand, ugh. My wife came in and saw my work and pointed out a few spots that weren't smooth. However, I do want my home built box to have a little character; so I've left the spot welds visible on the pockets, slight ridges where the pocket holes would be and ripples on the front panel. This isn't going to be a show truck so I'm happy with the result so far.
As for building character, perhaps when I'm done I should just haul stuff in it and bang it up some! I would love a photo one day of this truck with my KX250 and my wife's KTM125 in the back!
https://goo.gl/photos/1hn7RJf3KTTkJjm78
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
I sanded the top tubes pretty darn smooth and also the fenders. I haven't yet done the extensions yet. I do have a couple slight imperfections to tackle so I sprayed down another build of primer. Looks pretty good. Plus I worked on the new 1/2 ton box sides this afternoon.
https://goo.gl/photos/cpwfo12QqZQVLqgy8
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
This year for goal setting and tracking our goals, my grade 2 class and I set various goals and we have been using each other as "accountability partners." They have set their reading and exercise goals and I decided to set a goal of truck painting. My goal was to have the 1 ton painted and body assembled by end of June. I really am feeling the pinch here! Don't know if I'll make it and my grade 2's sure are eager to call me out if I didn't work on the truck the evening before. The rear fenders are done (FINALLY!) but still need to body work the fronts, hood and extensions and doors. And then paint. I need at least a SOLID week (or more) to do all this (12hr days).
Plus NHL playoffs have really been cutting into my truck time!
and the 1/2 ton has been getting a little attention too 😎
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Nothing like a pack of 7-8 year olds to keep you in check...no pressure!
Lots more pictures
Fox
Offline
Well, I pulled the trigger and ordered rims for this one ton from etrailer- Dexstar am20766. Hopefully all goes well and they arrive when stated and the fit like all have said in the reviews and online. I now have to order some rubber from my brother!
By the way I bought some "new" used hubcaps for the old girl.
And I started body working the dually extensions too. Ugh sanding.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox
Offline
I'm almost done sanding out the fender extensions on the one ton! Hopefully ready for final primer coat Saturday.
My rims also came in and I distracted myself from sanding a little tonight by test fitting and seeing how they looked... Look great and fit great. I then distracted myself more from sanding by removing the hubcap clips from the original rims.
https://goo.gl/photos/8eb5rKhGRd2uUuTBA
https://goo.gl/photos/MoSmAQ4Uafqn6L4Y6
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Hi Fox. The project is getting closer to being done. The new wheels are a asset and it will be nice to have a rolling chassis. Your students are a great motivator.
It probably will not be done for History Road this June but if you make it Doyle and myself will be there with our One Tons and I will look forward to shaking your hand and buying you a coffee.
Take care. Howie
Like the Fat Tubing on Box & Fat Fenders - Good Looking - Beast .
Your life is made up of Two Dates and a Dash........make the most of the Dash.
http://www.fossilcars.com/chevrolet/1-ton-pickup/869217
Fox
Offline
Thanks Ton.
Howie,
I plan on coming out to Reynolds and I look forward to meeting some Bolters in person. Can't wait to see some other one tonners too. They really do grow on a guy eh? Any chance of getting your 62 in the show, too? I'll pm you closer to the show.
Well, I think this weekend has finally seen the end of the box body work. It's pretty darn straight (not concourse style) but I'm happy with it. I shot another coat of primer on Saturday but will double check with guide coat and will then probably give it one more before top coat. Looking pretty good, now onto the front end.
I also tore into my parts truck today to get the wheel cylinder adjusters as I had a couple broken teeth on the star adjusters of the one ton. The drum came off very nicely considering the old girl had been sitting in the trees for 30 years. I also finished removing the clips from the old rims. I have 17 clips in a ziplock bag ready to go. I don't know about you guys but I always seem to need a spare when working with old truck stuff...
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Moderated by  Dusty53
