0 members (), 106 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
Is there a preferred way to assemble the inner and outer fenders to the cab and core support? I have seen guys assemble the inner fenders to the outer fenders then as a combined assembly attach them to the cab and radiator core support. I am finishing up on the paint work and since I do not have help regularly, I need to do this myself and hopefully without screwing up my paint. If I am to attach each part individually, do I hang the outer fender before the inner or vise versa?
Thanks in advance.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
You will screw up the paint if you try to do this by yourself.
The next one I do, I am going to to pre-assemble the entire front clip including fenders, inner fenders, radiator support, and grill. I will then acquire some trusted souls to assist in attaching the front clip unit to the cab. This is how GM did it.
Carl
I assembled my inner fenders, then radiator housing etc. Only snugging the bolts. I had a friend help me hold and bolt the fenders. Then he helped me lift and bolt on the hood Matching old marks on the fire wall. Then started the shifting and lining up of fenders. The worst part of the front end was the front grill and fenders. It all worked out great. With finished parts, And care.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Thank you both for your input. All appreciated.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
