1 members (J Lucas), 94 guests, and 0 robots.
Topics128,049
Posts1,055,635
#1228931 08/07/2017 9:26 PM
Hello fellow bolters!
I am getting ready to replace the valve stem seals in my 1954 Chevy 235 this week and have done a lot of reading up on this subject and I see that several folks recommend going to umbrella seals (same ones that a small block uses), so I am wanting some recommendations on which ones to use, please and Thanks!
Hopefully something that a local parts store carries or can get in short order.
Thanks in advance!!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
kthomas #1228938 08/07/2017 10:26 PM
Be careful- - - -there's such a thing as too much oil sealing. If you go with umbrella seals (really foolish idea, BTW) take the O ring seals off that fit below the split keepers on the valve stem. Valve guides need to have a little lubrication- - - - -running them totally dry with too much sealing wears them out and creates massive oil consumption that no kind of seal can cure.
Hello Jerry!
I can definitely go with the o-ring seals. I seen some conversation back & forth about the umbrella's on another forum so just thought I would ask. As always, I appreciate your input!!
kthomas #1228946 08/07/2017 11:22 PM
I have seen many umbrella seals crack rendering them useless.
Stock O ring seals seldom fail if installed correctly( I always vacuum test them once installed).
I have only seen one engine where the O rings failed. That engine had sat for many years and the seals did dry out and crack.
My Blog
kthomas #1228951 08/08/2017 12:04 AM
Are we talking about positive valve stem seals? The kind which are affixed to the valve guides? Or the kind of umbrella seals commonly used on older Furd engines
kthomas #1228965 08/08/2017 12:59 AM
Yeah, I will be using the original o-ring seals for sure!
52Carl #1228968 08/08/2017 1:17 AM
Positive seals clamp to the top of the valve guide with a steel spring, and wipe the valve stem as it moves through the seal. An umbrella seal is a cup-shaped device that grabs the valve stem and rides up and down with it, deflecting the oil away from the top of the guide. Positive seals require a machined outside diameter of the guide and are usually used on race engines because they're very small diameter and allow the use of double or even triple valve springs. They're not really intended to be used on street engines that are expected to run for thousands of miles. I used a lot of positive seals on my round track engines, but a really old roundy-round engine might have 5,000 miles on it! Umbrella seals are a little better mileage-wise, but they still have a habit of getting tired and losing their grip on the valve stem.
kthomas #1229161 08/09/2017 12:37 AM
Thanks for the clarification Jerry.
I asked because I have tried the umbrella seals on a 216 and they deteriorated and split in no time at all. Must be they don't make them like they use to.
Carl
Carl,
Corvair guy says use Viton.
CTT
Originally Posted by chuckthetruck
Carl,
CTT
I am familiar with Viton. It is also resistant to many chemicals. Good to know they make umbrella seals with it.
