3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1227984 08/01/2017 6:59 PM
My '48 GMC originally 6Volt with positive ground has been changed to 12V with negative ground and has an aftermarket gauge cluster. Going back to an original cluster I know I can add a 6V inline resister to the gas gauge but will the change in ground from + to - be OK for the gauge? I do have a Chevy gas gauge that is from a negative ground truck that I could always substitute if the original GMC gauge won't work.
Thanks, Jim
Eureka Jim #1228211 08/03/2017 3:13 AM
Crusing in the Passing Lane
GMC oil pressure guages have a higher oil pressure scale, dipper vs. full oil pressure. The guage doesn't care, just have to reverse leads, ammeter also.
Ed
EdPruss #1228214 08/03/2017 3:25 AM
Thanks Ed. I'm learning as I go along. I'll be using the tech tip here on Stovebolt on how to install a volt meter into the cluster in place of the ammeter.
Eureka Jim #1228246 08/03/2017 12:44 PM
I believe he is asking about the fuel gauge, not the oil pressure. So you can reverse the leads on the fuel gauge with voltage drop device and all is ok?
