8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen),
127
Mod | | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I have a 1950 1/2 ton. I am assembling my bed and have looked at many pictures online of the placement of the support parts that run across the frame rails.I have three bars, and what I have seen is one bar goes behind the cab and the two other bars go on either side of frame curve over the axle. My problem is that my frame has mounting holes on the frame behind the axle but it does not have holes on the frame in front of the axle? Is there something different with 1950 beds from other years? What am I doing wrong? I could not find any installation guide to see detailed instructions.
thanks, skipper | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Skipper, if you will go to Mar-K's web site you may find install diagrams and/or instructions.ðŸ›
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mar-K used to sell instructions for around $15. They used to provide the instructions for free with a cetain size order. http://www.mar-k.com/index.php?p=faq(My post above was being worked on when Justhorsenaround posted his Mar-K suggestion.) | | |
