1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | 1949 chevrolet 3100
new gauge,new tank, new float and sending unit
Seems to read only to just over 1/2 tank when full ?
Any ideas ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 6v electrical system?
Original-spec (ohms) sending unit? | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Float arm might need to be bent to calibrate the float level. You can bench test the sending unit out of the tank with an ohmmeter to make sure that it is working properly then adjust the float level. Or you can do it the shade tree way...if your gauge showed low before you filled it and then went to half after filling it, you float probably just needs to be adjusted. I adjust with a completely full tank and disconnect my battery between adjustments. Bend the arm down in small increments until the needle points to where you want it with a full tank. Then you should be good to go. As an added measure of insurance, carefully watch your mileage between your next couple of fill-ups until you are sure that your gauge is working properly. You don't want to trust your newly calibrated float/gauge and assume that when the gauge shows that you still have gas that you really do! Better to use a belt and suspenders approach to watching your fuel by checking the gauge while also watching the mileage so that you don't run out and get stranded. Hmmm....wonder how I learned that!
Matt | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | ok , so need to take seat back out and remove unit and adjust
