| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Wondered if anyone could provide some insight. I have a speedo and gauge gasket set from Classic Parts and am stumped as to how to put these gaskets in the gauges. I know they fit behind the chrome bezel and there are 2 pieces of tubular foam rubber seal both different diameter. I assume 2 different diameter pieces of foam seal for each gauge. The thing is, the 2 together don't add up to sealing the entire circumference of the gauge face. What am I missing. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | What make, model and year truck are you working on? This forum covers everything from the beginning to 1972 for both Chevrolet and GMC... Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | posey,
In each new thread that you start, state the make/year/size-model of truck, and any other equipment that is pertinent to your question.
1954 235 1/2 ton (3100) chevy (pickup?) This information might be pertinent for you to receive useful/helpful information. | | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | 1954 Chevy half ton pickup | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not remember.
Maybe someone has a Factory Assembly Manual and will look up that part/assembly. (and get lucky, if it shows the seal)? | | |
