The cams are on a pre-programed panning tour. If video stops and starts to buffer, reload your browser or you can click on the red previously recorded stream line to back up. The player stores 4 hours of previously recorded video
When you hear tower say land on green dot or red or pink dot means the planes are leap frogging on a 8000ft runway.
There are multiple scanners scanning the frequencies. Listen to the player with the most Listeners: Example: KOSH Fisk VFR Approach Feed Status: UP Listeners: 129
