0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | I did my due diligence using google to search here. I read all the treads on offy-Fenton combinations as well as treads on manifold heat.
Background: Stock 235 recently rebuilt with Fenton headers, stock intake, and Rochester 1bbl in a 1954 3100. - currently no heat to intake
Bought a t5 and Tom Langdon dual 2bbl 32 Weber carb setup.
I plan on buying an offenhauser dual intake. I have not seen this setup first hand, however, the spacing looks tight (especially at rear plug)
Questions: 1. rather than welding the casting plugs, has anybody opened them up for fittings to heat the manifold with water (of course with a base plate covering the normal location?
2. Is there clearance on the back plug location? Front plug?
3. Does the water jacket (for lack of a better term) connect to them? They must since there is a concern of leaking.
4. is this a silly question?
If I thought of this, surely someone else has.Inquiring minds want to know if this is possible
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | People have reported leaking at these plugs. I do not know how they sealed the leaks (high heat JB Weld?).
I have used both coolant and exhaust gas with your same set-up.
I prefer to use the correct 2-pipe-hole intake-base-plate that seals through the middle of the plate (with either coolant or exhaust gas/heat). The single pipe/hose plate does not take advantage of the end-to-end (in-and-out) flow that the Offenhuser instake provides.
I have used both coolant and exhaust gas. I prefer exhaust gas because it heats up the intake more quickly than the coolant does. I prefer exhaust gas, because the coolant "allows a disaster" if/when a hose breaks/leaks.
| | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | The best way to deal with the casting plug is have them welded shut (Heli-Arc? or something like that) using an aluminum plug.
It seems that the three big things I need to do to use an Offy header is: Grinding to fit w/ Fenton, Heat Plate, and Welding the Casting Plugs.
So, the brain says - I wonder if they could weld a fitting were the casting plug is and just use a plain plate for the middle for heating. I guess I better get my order in for the intake manifold and find out.
I don't know if it is hair brain or not -- I starting to think hair-brain as I doubt I can improve on Offy's method and the clearance room looks really tight.
Why water over exhaust for me: The toy will not come out in winter, so quick heating is not a necessity. Also, the argument that the hot water can perhaps lower the temp of the manifold on those dreadfully hot humid Iowa Summer Days - Whether it is true or not, I am not sure.
The counter point of using heat from the exhaust manifolds, which would eliminates a potential messy accident also weighs on me. It is a winter projects, so I have months to waffle back and forth!!!
This is one of the benefits of owning, I get to research, tinker, and start over if I do not like the results
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | I've proposed my own ideas about providing manifold heat that is absolutely goof-proof, but nobody was interested, so I quit suggesting it. Jerry
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | What Tim said .  | | |
