1 members (1 invisible), 69 guests, and 3 robots.
Topics128,081
Posts1,056,319
Members48,442
#1224518 07/09/2017 4:49 AM
Just started on restoring my dads 6400. Need anew master cylinder and front wheel cylinder. I tried searching. I think the master cylinder is mc9220. Is this correct? Does anyone have a part number for the front wheel cylinders?
Also, I believe the grills on these ar the same as the 3100s, is tantamount correct?
1948 6400
Check with Jim Carter Truck Parts, they are one of the few places I've found that carry 1 1/2 - 2 ton brake parts: http://www.oldchevytrucks.com
Master cylinder is item #ME166
Front Wheel Cylinder is item #ME130
1953 Chevy 3100 Pickup
1954 Chevy 6400 Grain Truck
1957 Pontiac Transcontinental
1958 Buick Limited 2 Dr
1968 Ford Galaxie 500
1974 Ford F-350 Flat Bed (Dump Bed), former Pioneer Seed Truck.
"Beer is proof that God loves us and wants us to be happy." ~ Benjamin Franklin
Rock Auto had parts for my 46 2 ton.
And good prices. Jeffrey
Rock Auto has master cylinder as Raybestos MC9220 and wheel cylinder as WC 4358. I think these are correct. Can anyone confirm?
Thanks.
1948 6400
8
8 Offline
Red75Bronco why not rebuild the Master Cylinder, and wheel cylinders that you already have? I rebuilt all of my wheel cylinders and my master cylinder on my '48 Loadmaster and had no problems. The most difficult part for me was getting the tension against the drums correct. By the way you should probably replace the rubber brake lines as well.
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
801curt #1224932 07/11/2017 12:31 PM
I need to get it the 150 miles here first. I can deal with the master cylinder, but the left front brake I cannot bleed. I have fluid to the cylinder, but nothing comes out of the bleeder even when completely removed. I need to get out there and take the wheel cylinder apart and figure out what's wrong. I would like to have the parts before I go though. Maybe I will get both the rebuild kit and the new and then return what I don't need.
1948 6400
If you have removed the bleeder and no fluid comes out, it's far more likely that it is a line or hose issue.
The bleeder is located right above the brake line inlet. The condition of the cylinder would have very little affect on the fluid flowing through.
When I loosen the line, I have fluid. I need to pull the when'll off.
1948 6400
It will be interesting to see what's inside the cylinder
I don't understand it either. It has been sitting for 10 years. The other cylinders are fine.
1948 6400
Brake line plugged or swelled. Couldn't get anything through it.
1948 6400
I replaced the master cylinder on my '51 6400 with:
Dorman M9220 New Brake Master Cylinder ordered on Amazon.com
$83
'64 Ford F-100
'51 Chevy 6400
That is the one I use has been working great.
1948 6400
