| | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | So I failed safety and one of the reasons (all minor) was the bushings on the lever potion of the shocks. The rear ones have a pin and cotter, but the front has a nut on one side. I've been pounding on it like crazy, does anyone know if it's just a pin with a nut, or if it's something else? I'm assuming a pin, that's just frozen up..... thanks | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Update - I've got both front pins spinning freely and the nut side through the buckle, but it won't pull through the rubber and other side. Could this be just a sleeve holding it in? | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Alright, I was able to put an allen key against the frame and pound the pin out of the shackle. The only problem now is that the bushing in the front is larger than those in the back! Has anyone replaced these before? I purchased two sets from Jim Carter, the only other one was for a double-action shock, but I'm pretty sure these are still singles, just different from the rears. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Can't answer you but will be having to address the lever action shocks on my 49 3100 one day. You may find the link useful 48 On line shop manual | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks Volfandt, It looks like the fronts are actually dual-action lever shocks. Only Jim Carter appears to have the bushings for them. Too bad, I was looking forward to a show this weekend  | | |
