1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 9 New Guy | | New Guy Joined: Dec 2016 Posts: 9 | Hey everyone, I'm looking for advice on how to get my 54 chevy 3800 with a inline 235 started. I have been able to get it to sputter but don't know how to get it to actually take off. I tried putting ether in it and that helped but it won't do more than a few puffs. The truck hasn't run in like 20 years and has pretty bad compression which probably doesn't help. I'm hoping the rings will pop lose once the block warms up. What should I do?
1954 Chevy 3800
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My advice would be to vary the timing back and forth in very small increments. There should be a small flange with a mounting bolt that goes into the block, at the base of the distributor. It has degree lines marked on it. Just loosen the bolt some, rotate and snug it up. It sounds like you are almost there. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Quit using starting fluid! Good way to mess up a perfectly good engine. Pour a tablespoon or three of gas down the carb instead. Read through and follow the Tech Tip mentioned above.
