8 members (ESum, Steelonsteel, TUTS 59, bobwithm, Maybellene, Ponchogl, Bill Hanlon, Gdads51), 96 guests, and 3 robots.
Topics128,088
Posts1,056,124
Members48,435
#1223244 06/30/2017 3:10 AM
Bought it 8-9 years ago and have used it here and there on a number of small projects. Works fine.
Until today. Have been using it on cab panels up to 2 days ago. Today got set to do a section of 200 or so welds and nothing.
Doesn't owe me anything, but I'll take it apart and see if it is repairable.
Anyone have any luck repairing them?
Never messed with one, but I'd start by checking where the power cord connects to it. Might be just a cord with a broken internal wire. If it has an on-off switch. That would be my next check.
After that (especially if it has a circuit board attached), the next step would be break out the HF 3-lb hammer and use that on it. wink Fixing electronic stuff just isn't worth the time.
There is an tutorial that shows you how to make your own spot welder. It might have information in it that helps? They yes the transformer out of a microwave.
www.instructables.com/id/How-to-Make-a-Spot-Welder-for-Cheap/
Dave from Northern Kentucky
My 54 3100
Nothing more than a failed solder joint at the power cord.
Of course the plastic plate that mounts the switch broke when I went to check the switch. Badly molded piece of crap.
10 extra minutes to make a new one.
Back to work.
Nice fix Jim! Good thing, because those are heavy and you could rip out a shoulder seeing how far you could throw it if you couldn't have fixed it.
A good friend of mine (who has a bit of a bad temper) has a swamp behind his house which is littered with HF tools. I envision archeologists in the future excavating that swamp and concluding that China was indeed part of North America in the ancient past.
Glad I could help. wave wink
LOL. That's about right! grin
Moderated by  MNSmith
