5 members (55shaker, Charles in CA, JW51, Southerntruck, Gray_Ghost), 100 guests, and 1 robot.
Topics128,052
Posts1,055,725
#122311 10/03/2006 3:56 AM
I have a '49 3600 and I am painting piece by piece and cannot figure out how to remove the door handles? I took out the screw behind the handle as well as the one in the door that does straight back into the handle...it will still not come loose? Any recomendations?
Also, how do I get the glass out of the door?
#122312 10/03/2006 6:22 PM
hey spencer, you've taken the screws out, so i don't know why it won't come out. you might try gently popping it with a rubber mallet to see if that might persuade it. the gasket may have bonded itself to the door and door handle over the years. As to the second question, the answer is: very carefully! grin if you have a truck shop manual it will give you step by step directions on how to remove the door glass. if you don't have a copy of it, go to online manuals and look there. www.chevy.tocmp.com and scroll down to it. make sure your hands are clean and not greasy and make sure that your tongue is out and at a 45 degree angle pointing downward.
#122313 10/04/2006 2:10 AM
Thanks, the link to the shop manual will come in very handy as I put this thing back together over the winter.
#122314 10/05/2006 3:02 AM
those handles just need to be jiggled around, I wouldn't go smacking them much with a mallet- you might F up the door skin.
