2 members (Tstan7, Napco Mark),
75
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | I am restoring a 53 1/2 ton . The doors are not closing correctly because of worn hinge pins. I see that oversized pins are available. Does this usually correct the problem. do the hinges need to be drilled to accept the new pins? any advice please THANKS
Popa Kents Body Shop
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Classic Truck Shop has a technical article on one type of hinge repair . | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you want the whole story by an expert, go to the OldGMCTrucks website, go to the Metalshop and read the post in there about hinges. There are a few threads on this site too. The Classic Truck Shop article does not give you all the information that you need. | | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | Thanks for your replies,just a few more questions. I found the info on classic truck,sounds like a good job for a machine shop. Do you now who sells the kit, or do I just get some pins and bushing of my choice I have several in the shop. Do you know of anyone that does this repair? I could not find the metal sop or any hinge info @ oldgmctruck. thanks very much
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | popa,
If you want the style repair kit as shown on the Classic Truck Shop tech article, Chevy Duty (Classic Parts of America) used to sell that style.
If you want oversized pins, Jim Carter used to sell them and any NAPA should have them.
Tim | | | | | Joined: Dec 2004 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 19 | How to rebuild you door hinges.
This is for 47-55 GM truck but may work on others. Getting it apart, Do not try to press out the pin damage to the frame will result 90% of the time. The pin siezes in the hinge arm and rotates on the frame. The pin is often broken. On a good hinge the hinge arm moves on the fixed pin. On the frame there are (2) 5/8" OD bushings spot welded. Use a die grinder and cut right through both of them. The hinge arm can now be removed,heated and whats left of the hinge pin driven out. On the hinge frame you will see the holes may be egg shaped. If you do not have a milling machine weld and file the hole so the center is in the right spot BEFORE drilling oversize. make some new bushings to replace the ones that you cut on the hinge frame. The local hardware store shoulds have some mild steel 5/8 bar stock. Drill a hole for the oversize pin. A lathe is a big help but it can be done with out one.
On the AD trucks they have a oil hole in the hinge arm. I have some times spot faced them there and added a grease fitting
Adjust the bushing thickness so the arm will fit into the frame. Then assemble the hinge and place 2 or 3 small welds to hold the new bushings in place and your done. Door hold open springs: The repop ones are heat treated wrong or something most will break in short time. A used original is a better choice and they still have breakage problems. If you buy repops get a few extra. Update on the hold open spings: I've been told the problem has been corrected and new ones now should work fine. Most rebuild kits come with some brass or bronze bushings throw them away they have too little contact area. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Trucker, do ya think you can supply a link to the GMC website? Denny Graham Sandwich,IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | Denny, Here is the link for the GMC website, http://www.oldgmctrucks.com/
Gary, Kelly, and Family
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Denny Graham,
If you use the LINKS icon at the top of the page, you will find the GMC site, along with many other sites. Explore a little and you can find just about anything a Bolter could desire.
Stuart | | |
