5 members (Gdads51, Gray_Ghost, 3B, DennisM, rick46ia), 34 guests, and 2 robots.
Topics128,022
Posts1,055,362
Members48,420
#1222660 06/25/2017 5:42 PM
Hi guys .. just installed an exterior sun visor on my 1950 3100 . I dont believe its a fulton annd has rather squarish corners a bit more so than the cab It has a bout an inch space across the top of the cab and obviously a bit more in the very corners .. Looks good and is solid, but now I have air turbulance noise , not a rear whistle but definatley rather anoying .. It has brackets that will let you rotate ( tilt ) it more or less .. Do you think changing the angle will help or is there no cure Thanks Fred
Fast Fredy #1222691 06/25/2017 11:09 PM
Need Pics .
Hard to say if the angle matters , but surely worth a try .
I recently added a visor to my '40 and have no added noise.
I also have a roof rack on my '76 300D and it fair whistles in some winds . Other days not at all , Just added that to suggest shape may matter , is it worth considering a subtle trim of the visor corners??
Fast Fredy #1222697 06/26/2017 12:57 AM
Thanks Dusty .. I'm going to try to block off some air in the corners to see if it makes a difference, if not I'll change the angle
