0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | Hi guys .. just installed an exterior sun visor on my 1950 3100 . I dont believe its a fulton annd has rather squarish corners a bit more so than the cab It has a bout an inch space across the top of the cab and obviously a bit more in the very corners .. Looks good and is solid, but now I have air turbulance noise , not a rear whistle but definatley rather anoying .. It has brackets that will let you rotate ( tilt ) it more or less .. Do you think changing the angle will help or is there no cure Thanks Fred | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Need Pics .
Hard to say if the angle matters , but surely worth a try .
I recently added a visor to my '40 and have no added noise.
I also have a roof rack on my '76 300D and it fair whistles in some winds . Other days not at all , Just added that to suggest shape may matter , is it worth considering a subtle trim of the visor corners?? | | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | Thanks Dusty .. I'm going to try to block off some air in the corners to see if it makes a difference, if not I'll change the angle | | |
