1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Rochester B on 1950 216. The carb is a 1952 or later (no part number available but two holes visable on crossbar). Truck sat for several months without running and carb was dry with red dust in fuel bowl. Took it apart for cleaning and flattening distorted gasket surfaces. Saw that the pump leather (?) was a little ragged along the bottom edge but seemed to seal when tested before assembly. Hard to tell how much is squirted into the throat looking down the carb since the pump discharge port is under the crossbar.
Any ideas before I tear the darn thing apart again? Can i pick up a replacement pump leather (and installation cone anywhere?
Thanks, Bill
| | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Just found that the flat plate pump "rod" has to be replaced to get a new piston. Mike's wants over $20 for this part alone. Any ideas?.
