9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop), 105 guests, and 2 robots.
Topics128,048
Posts1,055,626
#1221922 06/19/2017 1:52 PM
I have a fresh air heater in my '49 1/2 ton. I put in a rebuilt valve on the firewall, but it always blows hot no matter which way I turn it. Did I do something wrong? I installed the valve according to the assembly manual. Thanks for any help.
wiyello49 #1221934 06/19/2017 3:36 PM
Hose from thermostat housing goes to valve connection closest to firewall, hose from other valve connection goes to one heater core connection. The other heater core connection goes to water pump. If you're connections are this way it's correct. Feel the hoses that go to the valve. Heat on hoses feel the same, heat off hose going through firewall should feel cooler. An infared thermometer might help here but I'm not sure. If both hoses are hot all the time your valve isn't working properly.
Ed
wiyello49 #1221967 06/19/2017 8:51 PM
Ranco Valve? If so, I don't think that they shut off all of the flow to the heater.
You may want to add a cutoff valve at the water pump for warm weather driving.
52Carl #1222311 06/22/2017 6:29 PM
Yes, it is a Ranco. I was thinking I would probably have to put a cut off valve in the heater hose. Thanks for the info.
