1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | After Homecoming, I made a plan to get my 41 (350/700r4) running, moving, and stopping on it's own before the end of June. I've been working towards that and MAY make it. Anyway, I put a power brake system on it. I ran into some issues with my rear end, so decided to install front brakes only--for now--just to reach my goal---a deal with the rear end later. That way I can test out all of the other systems.
My question is, can I just plug the outlet on the master cylinder that leads to the rear brakes and expect the front brakes to engage properly, or will that not work?
Thanks for you help.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy VEW, I don't think plugging one system will allow the other system to function properly if at all. Does your new system have a combination valve incorporated into it? What problems with the rear brakes could be so severe that you would even consider just having functioning front brakes? | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Thanks 3B; that's what I was thinking as I was lying in bed this morning.
Well, it started with you :), You may remember you helped me identify the rear end in my truck as a 55-59 HO52 FF 3/4-1ton. I found that parts were difficult to get for them, like brakes. My desire was to run dually's (8x19.5), so thought it would be good to go with a 14 bolt. So, researched those for a couple of weeks, and know I need one from a C&C. One thing lead to another, as they usually do, and this put me way behind my schedule. That's when I decided to deal with the rear later.
But now I know I need to do something different.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Ruffstuff specialties sells brackets for the HO52 to mount discs on it. I bought the entire setup and when my drums dies someday I will swap them.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Thanks for the info Chad.
I found some brake wheel cylinders on Rockauto yesterday. That will enable me to put everything back together to get it moving and stopping.
I do want to run dually's eventually. But can't swing it right now. I'm at the point that if that's the ONLY thing I need to deal with, I'm a lucky man!!!
