| | | Forums66 Topics128,142 Posts1,056,481 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | Don't know what the parts may be or be called, as they are not there, but I have new door glass with the frames and the lower frame has 4 weld-nuts and the phillips head screws, but in the door, the window regulator has the typical 2 rollers. No parts were found in the door insides. The PO has no clue. I don't find the parts in the linked suppliers info. Must be a part that goes between to connect the rollers to the window frame. The truck is a 50 GMC. What the hey. Thanks in advance ( design ) Jon | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I can describe a little of the AD setup that has the vent window. The main glass rides in a channel both front and back. The back channel is semi flexible and the front channel is mounted on the vent divider. The window mechanism has one arm with one roller on it. It rides inside the channel rail that is mounted to the bottom of the glass. | | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | So, does the roller channel bolt on to the lower frame on the glass via the small bolts then?? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Mine are packed away right now and I can't remember but there were either small bolts or rivets. | | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | The PO found them in a box. It is just a simple rail with a hole to attatch to window frame. The rollers go into that rail. Thanks. Now onto the search for the tailgate cables. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | |
