1 members (TooMany2count),
120
Mod | | | Forums66 Topics128,193 Posts1,057,257 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello Gents,
I've worked on my 45 1.5 ton Park brake linkage recently having to create a new cable system which works great, however the E-brake lever inside the rear drum is not making full contact with the brake shoes. On the outside wheel plate, the lever that the cable connects to will only pull forward the the "half-way" position when pulling the handle fully back. Upon release of the handle, the rear lever will return fully toward the rear of the backing plate. Question, is the lever system inside the drum adjustable? I've already adjusted the brakes shoes using the rear adjusters on the backing plate. Thanks | | | | | Joined: Mar 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 35 | Been awhile since I have played with the brakes on my old truck, but did quite a bit years back. The only adjustments were on the brake lever (cab) side. There was a metal rod/yoke type deal that was threaded that attached to the lever (under the cab). That goes to a bar that has 2 ears on it that goes to the cables that goes to the rear end. You could take slack up there to so the lever system inside the drum "just" touches the shoes. Same idea as adjusting the pads to the drums. This is how I did mine. If you've already used up all the threads on the rod you could try clamping the cable to the rod with vice grips or something of the sort to see if your travel is good.
