5 members (55shaker, Phak1, 49fastback, Biermann, Jaison), 106 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
I am working on a 1950 Suburban Street Rod and want to prevent ANY moisture from penetrating the floor from the underside and I plan on installing a "pick-up style floor with skids. So might there be suggestions for putting down a "moisture barrier" prior to installing the wooden floor? I know Quiet-Ride Solutions has a "foil" product but I am looking for something maybe a little less likely to get torn by an errant road rock. Any suggestions? Thanks, john
JohnB
U
U Offline
430 stainless steel sheet metal comes to mind. 22 or 24 gauge would work.
Brad
Wrench Fetcher, PhD
Big Bolt Forum Moderator
you could roll the bottom of the floor with bedliner
Mike
