| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, I got a 6 lug 12 bolt rear which I was told came from a 1970 Chevrolet C10. I searched for the numbers and did not see this listed Pass side axle tube TRO313W2 some on the case 67890 then 12346 and A24. Any ID help would be great. Thanks Steve | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | I read that GM trucks through 69 use 2 lettters for the axle code. 1970 up use 3 letters. So its possible that you have a 68 C10 rear end according to this source http://www.gmcpauls.com/67-72_chevy.htm.TR = 3.07 03 = month 13 = day W = Warren, Michigan plant 2 = second shift
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thank you I should of looked back in years a little further.Steve | | |
