6 members (FAST55, Eric P Jr, Alex52, Frank50, Goach2, Hotrod Lincoln), 93 guests, and 3 robots.
Topics128,188
Posts1,057,220
Members48,465
I reinstalled the old fuel pump on my 216 today. Last year I had replaced it with a dual action pump in hope of improving the performance of my vacuum wipers ( no luck there). The old pump now leaks like a sieve. It worked fine when I removed it last year. The gas seems to be coming from the bottom ( the pump is mounted with the glass bowl on top). The connections are not leaking. Is it possible that sitting in the box in my shop for a year caused it to go bad?
My dad always told me, "Don't force it, get a bigger hammer".
Yes, because seals and diaphragms dry out and then leak.
Jeffrey
