| | | Forums66 Topics128,188 Posts1,057,217 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 184 'Bolter | | 'Bolter Joined: May 2003 Posts: 184 | I reinstalled the old fuel pump on my 216 today. Last year I had replaced it with a dual action pump in hope of improving the performance of my vacuum wipers ( no luck there). The old pump now leaks like a sieve. It worked fine when I removed it last year. The gas seems to be coming from the bottom ( the pump is mounted with the glass bowl on top). The connections are not leaking. Is it possible that sitting in the box in my shop for a year caused it to go bad?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Yes, because seals and diaphragms dry out and then leak. Jeffrey | | |
