6 members (EchoBravoSierra, carbking, WICruiser, 55Delray, Steve L., 1 invisible), 75 guests, and 2 robots.
Topics128,206
Posts1,057,438
Members48,471
I have sen these on 2 Ton Trucks and only ( 1 )
1 ton Truck - looked at 437 trucks . .
1st Series Truck , so what Gives ?
Were these an Optional Up Grade or for Heavier Haulers ?
Is it just a Dually Set Up ?
Your life is made up of Two Dates and a Dash........make the most of the Dash.
http://www.fossilcars.com/chevrolet/1-ton-pickup/869217
I don't quite understand what your're stating or asking.
3/4 and 1 ton GM trucks typically have 8 lugs or studs at 1/2" and later 9/16" diameter with 6.5" bolt circle and if hub piloted 4.56" center bore, dual wheels are hub piloted.
I've not seen 2 ton trucks with this 8 lug pattern.
I have also not seen 5/8" studs used on this pattern.
You can learn some about wheels and bolt patterns by browsing the Accuride catalog, page 27 is a good start.
Perhaps wheel part number 29015.
http://www.accuridewheelendsolution...ev-2-Accuride-Wheels-Product-Catalog.pdf
•1952 Chevrolet 3800 pickup
---All pictures---
