2 members (Uncles51, Rexville48), 64 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1219913 06/04/2017 12:58 AM
I have a 1966 GMC 1000 upgrading to V8 and using SM 435 trans, NP 205 transfer case, looking for overdrive unit.
I know about Gear vendors but was wondering about other overdrive unit options, also looking for deluxe windshield chrome trim.
medic8492 #1219978 06/04/2017 9:16 PM
Crusing in the Passing Lane
Do not know of any OD for a 205, other than Gear Vendors, if looking for lowered RPM at cruise speeds, change diff. ratios, unless you want to change trans.'
Ed
medic8492 #1225828 07/16/2017 11:36 PM
If you're still looking, Advance Adapters makes an overdrive unit called the Ranger Torque Splitter. It's a little two speed transmission that mounts between the bellhousing and the transmission. It has a 1:1 ratio and a 27% overdrive, giving you .73:1 in 4th high range. I'm thinking about using one in a Jeep project I'm working on. They're strong, compact at only 7ish inches, and everyone knows the more sticks coming through the floor, the cooler you are. This unit also allows you to engage direct and overdrive in any gear, giving you eight forward gears and two reverse gears, not a bad set up.
Joe
http://www.advanceadapters.com/categories/complete-units/91/
1954 Chevy 3800 Long Bed: ex-fire truck turned farmer's town run about turned 353T powered retirement project
1953 Chevy 6400: the work truck
medic8492 #1226495 07/21/2017 8:06 AM
My opinion: having more sticks coming out of the floor does not make you cooler. It just clogs up the floor.
1959 3100 Apache Fleetside
medic8492 #1226526 07/21/2017 2:54 PM
There's always the option of an air or vacuum shift for an over/under box if you don't want another shifter to play with.
Cablesmill #1227335 07/28/2017 1:48 AM
Maybe it's just a Jeep thing, then.
I know of one other overdrive, the Borg Warner R-10. That bolts to the back of a Dana 18 or 20, so you might be able to make an adapter plate to mate it to the 205, or swap transfer cases. That's like an actual little two speed transmission that is electronically shifted with a govenor or mechanically shifted with a cable or possibly manually controlling the solenoid. They're not produced anymore, but there is a guy that sells refurbished units and tons of parts.
Joe
CinkoJr #1227339 07/28/2017 2:16 AM
Who is that gentleman who rebuilds OD's?
Ed
medic8492 #1227368 07/28/2017 11:06 AM
http://hermtheoverdriveguy.com
His name is Herm. He's really knowledgeable about older overdrive units. A lot of the units he works with are for Dana transfer cases, but the Borg Warner was supposedly popular in hot rods and what not, so I can't imagine it would be too difficult to make an adapter for it
Joe
medic8492 #1227376 07/28/2017 12:36 PM
Joe,
Thanks, I had one of those OD setups in my Jeep, really liked it. Found one in a yard I have been saving.
Ed
