1 members (klhansen),
158
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 13 New Guy | | New Guy Joined: Dec 2010 Posts: 13 | I looking to order an oil pan gasket for my '54 235 truck engine. I keep seeing gaskets listed online for the years of 40-53 and then 55-60. 1954 is not listed? The 40-53 gaskets seem to have cork end pieces as well as cork side pieces. The 55-60 ones have rubber end pieces and cork side pieces. I've had better luck with the rubber ones in the past on other engines. I'm assuming the oil pan shape didn't change through the years. Will the 55-60 gaskets with the rubber end pieces work for my 54?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1940 (maybe 1937) through 1955st-series 216/235 engines used the same oil pan gaskets. Jim Carter Classic Parts | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937-39 used there own gasket. As Tim says, 1940-55 first series truck, or 1940-54 passenger car use the same gasket.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
"The reason 1954 is left out in parts listings is because the mid year change in trucks"
Mid-year change in truck 235 pan in mid 1954 or mid 1955?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Mid 1955 was a change over year in trucks. In rereading the first post I see no reason to leave 1954 out of the books.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2010 Posts: 13 New Guy | | New Guy Joined: Dec 2010 Posts: 13 | Thanks for the clarification, the site I ended up to order the gaskets was very confusing.
I have a set of the rubber end pieces from the post 55 gasket set. Do you think I could use them on the 54 instead of the cork end pieces? I've had better luck in the past with the rubber over the cork. I understand that the side pieces are shaped different, but are the rubber ends usable.
Thanks for your help | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have used the rubber in place of the cork in the past with no problems.
