1 members (GMCJammer51),
92
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 34 | Can I swap a set of front fenders off of a 51 Chevy school bus with the front fenders of a 48 chevy AD 3/4 ton? Have a great set to work with if they will work.
Still At It
48 Thriftmaster 64 Impala 62 Impala
Half the fun is making the mess!!!!!The other half is figuring out now what do I do?????
| | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | what size is the bus?the wheel opening would be different(larger) for 1.5 ton up ,due to larger wheels. 1/2-1 ton fender openings are the same. tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2004 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 34 | I think it is a 1.5 ton. Has the 18" wheels I would guess.
Still At It
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | The wheel size might not matter. I considered a similar swap for my 62, 3/4. I believe that the problem will come in with bolt hole alignments.
delete my account and pictures
