| | | Forums66 Topics128,157 Posts1,056,878 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 2 Moderated | | Moderated Joined: May 2017 Posts: 2 | Once I remove the four nuts from the shackles on the front springs how do you get the shackle side plates off? Are they taper fitted onto the bushings or is there something else keeping them from coming off? I've tried heat and a hammer but am reluctant to use too much of either. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They should tap or pry off. You have to take the weight off though. Put the axle on stands & raise the chassis enough that no weight is on the springs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | They can be tough to remove. They've probably been untouched since the truck left the factory, and wear can create grooves that hold them in place. It may take fussing with the jack to get the proper alignment for removal. I know on my one ton it took a lot of effort to get them apart, but they will finally come off. Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | There is a slight taper. Once you get the weight off the springs they will come off with a little persuasion.
AC Delco still makes the replacement parts with the correct bushings, bolts, soft gasket, washers, etc. The nuts aren't the same as original and are slightly thicker, but otherwise, it's all the same as the old stuff.
Amazon has them for around $24, much cheaper than the truck supply houses. AC Delco 45G13044
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
