1 members (Shade Baby), 147 guests, and 0 robots.
Topics128,162
Posts1,056,940
Members48,458
Moderated
Moderated
Once I remove the four nuts from the shackles on the front springs how do you get the shackle side plates off? Are they taper fitted onto the bushings or is there something else keeping them from coming off? I've tried heat and a hammer but am reluctant to use too much of either.
Riding in the Passing Lane
They should tap or pry off. You have to take the weight off though. Put the axle on stands & raise the chassis enough that no weight is on the springs.
1972 Chevy c10 Cheyenne Super
They can be tough to remove. They've probably been untouched since the truck left the factory, and wear can create grooves that hold them in place. It may take fussing with the jack to get the proper alignment for removal. I know on my one ton it took a lot of effort to get them apart, but they will finally come off.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
There is a slight taper. Once you get the weight off the springs they will come off with a little persuasion.
AC Delco still makes the replacement parts with the correct bushings, bolts, soft gasket, washers, etc. The nuts aren't the same as original and are slightly thicker, but otherwise, it's all the same as the old stuff.
Amazon has them for around $24, much cheaper than the truck supply houses. AC Delco 45G13044
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
