1 members (baldeagle),
40
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Short of sanding it all down and reshooting it, does anyone have any ideas on how I can fix this? It was shot in Alkyd and it was one of my better jobs, sans thumb print. Seems like the Alkyd paint is slower to dry because of no added hardeners. Was thinking of taking some 1000 paper to it and wet sanding it and see. Go from there. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Way slower to dry. put it in the sun for a week at least before any attempts to sand.
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | You could try polishing it. Or, leave it as proof that it's yours! | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Great replies guys thanks. Finding a week of sun around here might be hard,lol. We have had over 40" of rain since October. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Alkyd enamel needs a MINIMUM of 30 days' curing time before any attempt is made to sand or even polish it. The solvent evaporates out pretty quickly, but the carrier of the pigment ("binder") needs time to oxidize and harden. When quick-curing acrylic enamels and isocyanate hardeners came on the market about 40-something years ago, people started to forget how much hassle alkyd was to deal with. About the only place I see alkyd enamel for sale any more is "tractor and implement" paint, sold by farm equipment places like Co-Op, or Tractor Supply Co., etc.
The cyanide-based chemicals in isocyanate hardeners are contact poisons, meaning they can be absorbed through the skin. To use them safely, it's necessary to wear a full-coverage "shoot suit", preferably one with a separate air supply drawn through a good chemical filter. Some of my painter friends who used isocyanates on a regular basis have developed some pretty nasty chronic health problems from the toxicity of the products. Jerry
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The good news is that without hardner, the alkyde is much easier to repair. Assuming it is fairly fresh, carefully press a smooth shiny object onto the thumb print, like the back of a spoon. Just enough to flatten out the margins. Orient the bumper so that the mark is level and horizontal. Mix a little bit of the paint with a slightly higher than recommended ratio of Naptha. Use a small paint brush to fill the mark, making sure the paint is slightly higher than the surface. Leave it for a couple of days indoors. The solvent will soften the under lying paint and the edges will blend. You will have the a slight blemish at most and no one will notice it. Hint, always use hardener. The paint is much stronger and you can handle it after 24 hrs without leaving marks. | | |
