7 members (68ironhead, HandyAndy, jmoore, Rexville48, walter74, 6inarow, 1 invisible),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,567 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | OK so this is my first post. Got a 1950 5-Window that's my first project. I've had oldies before but have never tackled anything major. So I need to replace the following:
Cab inners & outers Rockers Cowl inners & outers L&R wheel house
Someone repaired these areas eons ago and didn't exactly use replacement parts. I dug bondo out forever along with all sorts of metal including a pie pan! Got the old stuff out and picked up replacement panels or fabricated otheres that I felt I could make. After reading the opinions here and trying a few different MIGs I decided to bite the bullit. Picked up a Millermatic 175. Great machine so I'm ready to weld. Anyway, I wanted to know if there are diagrams or pictures anywhere of these areas that I can refer too. The cab corners aren't really a problem but the remaining areas are. I've taken plenty of pictures during the disassembly but need to see what a good finished product looks like. Any suggestions would be greatly appreciated.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | Two suggestions. First is get a factory assembly manual from www.americanclassic.com or www.oldchevytrucks.com. You will be so glad you spent the $30.00. Second is just view the online catalogs of these vendors for patch panels. Not only can you get the panels that will help you do it right, just looking at the pics will give you an idea of what you need to do. | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Another tip that has been mentioned many times and is very helpful. Cut the patch panel to fit the damage, do not cut the truck to fit the patch panel. The more undamaged original metal with it curves and fits the better. | | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Thanks for the info. I also found some pics from another member that revealed quite a bit.
| | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | One other question. I noticed that the replacement rocker panels have a couple of holes on the front end of the panel. Are these holes necessary? These areas were so rusted I couldn't tell what they looked like originally. Also the rockers seem longer than the originals in the front, protruding forward. I've been reading that quite often replacement panels aren't exactly like what came on the vehicle. Any ideas? Thanks.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The big hole in the drivers side rocker is for the e-brake shaft. You can put bolts in the small holes to pinch the rocker,floorpan lip and inner to outer cowl together for fit up. The right side rocker has the holes but they do nothing. Must just be easier to stamp a mirror image. I don't know if the original rocker had holes on the right side...mine was rotted away as well. Personally I thought the outer cowl was one pc. that was best to drill out all the spotwelds and replace the entire panel but each situation is different. Good luck and be patient.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Hey guys you know these parts go over seas too, there are a few right hand drive trucks that use some of the holes you didn't think were needed. and one more thing watch out for NON US meatl parts you may have just $bought$ some rust made in your new repair. | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | jss1956,
From my recent experience when you put in your cowl panels make sure that you measure across the door opening prior to cutting the old ones out. When you weld the new panels back in you need to keep that measurement exact. If you don't your door gaps will be off.
Trust me after all of the work of putting them in you don't want to have to re-do it.
I didn't do this and it looks terrible. :mad: | | |
