0 members (),
155
Mod | | | Forums66 Topics128,167 Posts1,057,018 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 138 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 138 | I am the proud owner of a new project (a 1937 GMC Panel) but need help identifying some parts. In this photo, what are the two brackets sitting on the corners of the plastic containers? And what are those oval washers used for? 1937 parts on Photobucket In this photo, I'd like someone to ID the two similar parts, one is to the left of the accelerator pedal and one is to the right of the window cranks. 1937 GMC parts picture 2 on Photobucket Also, what is the felt looking part two parts to the left of the accelerator pedal? Finally, what are the two brackets at the bottom of this photo and what is the dual canister looking thing in the bottom right? GMC parts picture 3 on Photobucket If nothing else it will be fun to see what answers I receive! Thanks for your help! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | LH bracket looks like a rubber replacement for the neoprene cushion for the front engine mount that has two vertical and some coil springs.
The double, round canisters look like kerosene road flares out of a set of 3 to put out around a broken down truck.
Ed
| | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | These are tricky. I can say with fair certainty that similar parts do not exist on a 1938 ¾ ton Chevy panel, having had mine in pieces before restoration. GMC certainly had some variations in parts/style; the 37 and 38 years might be slightly different, and most importantly, if I recall correctly, your panel is a 1-ton or 1.5 ton–that is probably the most important factor; there are many variations between truck sizes. All that being said, I will venture a few guesses.
I have no idea what the round canisters might be. The previous post is as good an answer as I can come up with. The brackets near the canisters–if they are 3/16-1/4” steel, they might be part of the rear bumper hanger system (there are a couple variations for the panels), or part of the spare tire hanging system (again, several variations).
The oval washers in the plastic tub, seeing that there are about 9-10 of them, might be body to frame washers (the Chevys have a rectangular type); they seem to have about a ½” hole, which is about right for frame bolts. They might also be part of the bed mounting system/cross pieces for the wooden bed of the truck. I don’t know what the 90-degree angled brackets on the plastic container are–they don’t seem heavy enough for frame, but perhaps hangers of some sort for the fuel tank or other system (exhaust, battery), or body to wood bed again?
The brackets on either side of the gas pedal–are they channeled on the back side? If so, they almost look like part of the door/window regulator system. If they’re not channeled, not sure what they might be. The felt looking thing next to them seems to be some sort of pad; with the hole size, etc., it almost looks like it was used as a pad between body/frame/frame washer–Chevy has rubber ones. Perhaps a pad for a tank mounting strap? Is this the only one, or are there multiple ones? If there is only one, my theory above is probably wrong, but with the hole there, it must have cushioned something of that size.
Sorry not to be of more help–those are my best guesses at this point. One other thought–when I got my panel in boxes and containers (like you), I discovered that the previous owner had collected all sorts of parts and POTENTIAL parts. A lot of these “potential” parts either did not fit (they were from a ½ ton or a 1.5 ton) or they weren’t parts at all, but stuff that he had collected along the way and saved for one reason or another. I discovered this the hard way, trying to fit several of them in all sorts of places. When the truck was finally all back together, there were a bunch of these “parts” still around, but the truck was complete! So some of these things in your containers might not have any actual connection or application to your vehicle.
Good luck!
Jim
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Those canisters are indeed kerosene roadside emergency flares. The bracket would mount vertically with the canisters stacked one above the other. Take the little cap off to expose/light the wick and put it back on to put the flame out. Mike B  | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I am going blind I do not see the road flares. Though about a year ago near where my son keeps his 46 2 ton he was told about a farmer that has a AD 1.5 for sale.
So we went to look at it. Best park of the truck was it had an original metal case that held 4 - 5 original kerosene flares. The flares and case were in excellent condition due to never being used.
My son was surprised to learn what old time road flare technology was.
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | The flares are in the baking pan in the same picture as the sheet metal floor pans. Mike B  | | |
