4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I know this topic has been discussed before. I want to convert my oil bath air filter to a dry-type filter and still maintain the look of the oil bath and I followed the information provided in the Tech Tips. I am in the planning stage so I haven't cut anything. My problem is that the K&N air filter suggested for use in the Tech Tips (K&N E-9216) is no longer in production and there is no replacement filter from K&N. My search for a different manufacturer has so far been unsuccessful. I want to get a dry-type filter before making the first cut. Once I start cutting there is no return.
I am open for suggestions of other possible manufacturers and part numbers.
John | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I ordered one last week. It hasn't arrived yet, so I gave K&N a call after reading your post. I was told that they are still in production, but currently out of stock. The estimated date for shipping is July 11.
Matt | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | cmayna,
Thanks for posting the pictures. My current set-up is an oil bath air filter where the top part sits completely down inside the bottom 'bowl' meaning there is a certain amount of removing existing material from the top part to make the conversion. | | |
