0 members (),
347
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | I have sprayed my paint and clear, and have finally gotten to the point where I was able to sit down and start sanding and then.... I found a spot on the corner of the bed where I had sanded not only through the clear, but also the layers of paint. So now i am back to my bright white primer.
Any tips on how you would go about re-painting, or covering this sand through spot? It is pretty obvious so hiding it is not really an option.
Austin Jones
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Pretty much repainting that panel is the only choice. The whole panel vs blending are the two choices. Whole panel is far easier but obviously more work and materials. Hiding the blend takes high skills and experience .......most pros would just do the panel. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Pretty much repainting that panel is the only choice. The whole panel vs blending are the two choices. Whole panel is far easier but obviously more work and materials. Hiding the blend takes high skills and experience .......most pros would just do the panel. Yep.
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Pretty much repainting that panel is the only choice. The whole panel vs blending are the two choices. Whole panel is far easier but obviously more work and materials. Hiding the blend takes high skills and experience .......most pros would just do the panel. yep x 2 TIP: mask the edges with masking tape to avoid touching them when color sanding. If you don't, either the sand paper or the buffing will cut through. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | If you are just talking the edges of the panel, I would first try touching up the sand through area of base coat with a fine artist's brush. It may take more than one coat to adequately cover. Then lightly sand this with 600 grit, then either respray the entire panel or use an air brush or detail gun to touch up the edges with clear. Then be more careful with your sanding. Mike | | | | | Joined: Apr 2017 Posts: 17 New Guy | | New Guy Joined: Apr 2017 Posts: 17 | Thank you everyone, I never thought about the masking off the edges while buffing so that was a nice tip. I will just end up re-painting and clearing the area since that seems to be the only way, because I tried the airbrush and the paint came out to thick thus making it to dark.
Austin Jones
