6 members (Peggy M, Bucker, Hotrod Lincoln, klhansen, Hush, Tronman), 76 guests, and 1 robot.
Topics128,206
Posts1,057,435
Members48,471
porky here..
currently installing a new in cab fuel tank on '59 1/2 ton apache. someone recommended using a bike inner tube to place between the back side of the tank straps and the tank. any thoughts? i bought the tank floor pads from a part house but didn't see anything for between the straps and the tank.
what say ya'll?
porky-
1959 Chevy Fleetside 3100 Series BBW
put this in an eBay search:
"genuine GM gas tank strap insulators pads silencer anti squeak foam"
and it will take you to the stuff i used...
Porky, the best replacement for the rubber under the straps that I have found is glass setting tape. It's the rubber tape that you soak with oil to secure the door window glass into the metal frame on the TF trucks.
It is available in different widths and thicknesses. If you search "glass setting tape" on eBay, you will get several hits.
Local glass shops that specialize in car window replacements usually carry it in large rolls and will sometimes sell you the amount that you need.
I get it wide enough to overhang each side of the metal strap by about 1/4" because that's how it looks on the stock installations. I think the overhang helps to protect the tank from the sharp edges of the metal straps.
This is the stuff that I use for in-cab tanks. It works so well and looks so much like the original material that I sometimes wonder if this is what the factory used.
Good luck,
Matt
Great idea Matt. Steve
