4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
Hello!
My goal this spring is to get ol' Gertrude tuned up and happy. She is in desperate need of an oil change.
What weight oil is a good year round oil? She doesn't get driven enough to require much more than bi-annual semi-annual oil change.
How much oil does my 235 require?
Anyone know a good place to get the old school canister oil filters?
Thank you!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Lots of trustworthy sources here use a 15w-40 diesel oil.
Filter depends on what kind you have. Mine takes a Fram C4 or equivalent. Can't remember the wix number off the top of my head.
1951 3100
10W-30 was recommended by GM
10W-30, 10W-40, 15W-30, 15W-40 would be OK
bi-annual - every two years
semi-annual - twice a year
Factory recommendation: 2,000 miles
I usually change mine annually (once a year, in the Fall), unless I travel more than 2,000 miles in a year.
5 qts plus capacity of oil filter (if installed - 1qt or 2qt, usually)
Oil filter changed every 2,000 miles
There were many styles (brands/sizes/years) of filters that were used on 235s.
Do you have an owners manual and/or a Shop Manual?
tclederman -
Thanks for the grammar edit, I fixed it above.
I have the owners manual somewhere. She has been in storage for a little over a year, still trying to sort out all my manuals and documents from a move / divorce. I know that dang manual is somewhere.
Does anyone run Lucas Oil Stabilizer? My 1993 GMC with the 6.5td loves that stuff.
Kyle
My Machine
Kyle,
I understand lost/hidden/stored manuals. I moved to NC around a year ago and I am still looking for manuals/documentation.
Regarding oil filter: you might find yours in this Stovebolt.com Tech Tip
Good luck with your truck.
Related question. The bypass filters were optional equipment. They add a quart of capacity. I believe it will drain to crankcase when not running.
Fair to assume dipstick will be inaccurate after engine sits a while?
1951 3100
GM optional 235 by-pass oil filters we usually 1qt, but a 2qt filter was also an option in many years.
One was on my 1954 3104 235 engine (RPO canister was painted black).
So what about the dipstick issue I mentioned?
1951 3100
The 15W-40 diesel oil lubricant is traditional oil from petroleum.
I've noticed that synthetic/traditional blend is 10W-40.
Pure synthetic is 5W-40.
I take that to mean synthetic is a much better lubricant at cold temperature and they can get away with a less viscous oil on cold startup.
I use 6 quarts 10W-30 Mobil One synthetic (NAPA 1072 bypass oil filter) in my 261 and now change it once a year although I could go much longer than that. It gives me a chance to crawl under my '48.
Put in 5 qts at an oil change and check the dipstick.
It should read at the mark.
If you have a 1qt oil filter (that drains back to the pan with the engine off), add one qt of oil.
Then, check the dipstick and scribe/mark it at the new level.
Or not
