1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | I need to replace the hinge pins in my 45 GMC 1/2 ton. While doing so, i would like to replace them with a kit that uses bushings. also, I need to install the mirror bracket into the assembly. If I install everything now, will there be enough room to paint it properly? If I paint first then assembly, I am concerned that I will damage the paint during the installation. Any suggestions where to buy the longer style pins, and bushing kit?
Installation suggestions appreciated as well. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They were probably assembled before they were painted at the factory.
