2 members (Ponchogl, Shardean), 56 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
What should I start looking for in order to replace the frame and the drive train in new (new to me) 54 3100 1/2 truck. Cab and front are in great condition but the frame and bed are bad. I just want it to be a local driver was thinking 4.3 or 305 engine AT.
Jeeper, Posting the same question in multiple forums is considered poor site etiquette. Again I refer you to the HiPo Shop forum for your "modification" answers.
3B Offline
Hy jeeper, welcome, we have a member here Robert Hertz he owns Advanced-Design Engineering. www.AD-ENGINEERING.COM, he makes kits to install AD bodies on S10 chassis, hope that helps.
H Online: Content
That website says "Business Closed". If you're pretty good with a pencil and a welder, adapting the body and bed to an S-10 frame isn't terribly difficult, and the running gear will be 50+ years newer with parts much more available. IIRC, the S-10 frame length can be adjusted by cutting away a few welds and sliding the front and rear sections in and out to achieve the desired wheelbase. Have fun!
Thanks, I'll start looking in the local yards.
